For a 1976 A150M Aerobat:
26-04-80A strut fairings will not fit! These are for NON-Aerobat. The Aerobat uses a wider, thicker strut. Until just a few years ago, Aerobat strut fairings were only available through Cessna!
Stene Aviation [
steneaviation.com] has recently come out with a set of fiberglass replacement strut fairings for the Aerobat.
150/152 Aerobat Strut Cuff Upper Right SA-0421002-3 $82.50*
150/152 Aerobat Strut Cuff Upper Left SA-0421002-4 $82.50*
150/152 Aerobat Strut Cuff Lower Right SA-0522150-6 $82.50*
150/152 Aerobat Strut Cuff Lower Left SA-0522150-7 $82.50*
* PMA Approval Pending
I have been very satisfied with Stene products. Their's is a very thin and very strong fiberglass made with layers of closely woven material. They appear to be manufactured by vacuum bagging, and there is no excess weight, with a good finish.
I believe
Aerofairings [
aerofairings.ca] of Canada has these in ABS plastic, at about the same price. I have not dealt with them before.
26-06-80A landing gear fair. Good number. These will work!
26-07-80A brake cover fair. These should work.
Aircraft Spruce is a very well know supplier in the states and I have always had fast and courteous service from them. I have no opinion on the parts you've listed from them.
