#631015 11/09/21 11:35 AM
I recently purchased a salvage 1966 C150 that I needed some components for my projects but many remain. Wings are unusable but the remainder has many good parts. Total time 2400 hours Engine/Airframe frown. Let me know what you need very reasonably priced.
Terry
https://www.aircraftsalvageonline.c...e68845aa-0ebd-45a5-ba68-648544e4a205.JPG
https://www.aircraftsalvageonline.com/Home/AircraftDetails/3788#6
Seats, cabin speaker, fuel tanks intact?
Shawn
N3091X
Based: KBAF
Standard or long range wings?
Experience is a hard teacher because she gives the test first, the lesson afterward.
The only time you have too much fuel on board is when you're on fire.
1 standard fuel tank good(might have a second from another project), seats good. Not sure about the cabin speaker, I'll have to check
B
B Offline
fuel quantity gauges?
how much for the engine and or for the remainder?
Also! you have two cups! the first is called "luck" the second is called "experience",
The task is to fill the second cup before the first runs out!!
You're killing me. I have airframe components, engine, prop, instruments, and radios to get that 150 back in the air.
Hi Terry.
Good of you to offer the parts! I know you said the wings are unusable, but I was wondering if the two door stops (one on each wing) were okay. I need two of those, and they are hard to find.
Thanks!
N
N Offline
Hi Terry, what serial number is the project I'm looking for good 6"axles and wheels? Thanks, Nick
