1967 Cessna 150G N8547J (aka Scooter)
- - - - - - - - - - - - - - - - - - - - - UPDATE 06-13-2017 - - - - - - - - - - - - - - - - - - - -
0-200 engine recent inspection (06/13/2017): Cylinder bore scope, all valves, walls, and piston heads reported as normal, no cracks or burns. Cold compression test reported as 1=74/80, 2=78/80, 3=74/80, 4=72/80. Plugs good, cleaned and set. Changed oil and filter, sent oil sample to Blackstone Labs, which report engine has no obvious signs of trouble.
TTAF: 3333 hours
SMOH: 1516 hours
Last Annual: 12-17-2016
Narco CP135 TSO switch
TKM MX11 Comm
Narco AT 150 TSO transponder
Attitude Gyro, Directional Gyro, VOR
Alcor EGT
Sporty's Flight Timer
Flightcom IIsx Intercom
Bruce's Prop Cover
Bruce's Pitot Cover
Bruce's Intake Covers
Bruce's Windscreen Insert Reflector
3 New Tires (nose + mains) GoodYear Flight Special II
Aero Fabricators Dual Harnesses
Belly Fuel Drain
Hoerner Style Wing Tips
Micro AreoDynamics Micro Vortex Generators (VG) + replacement kit
Wheel Fairings - matching paint
Log books, parts manual, service manual, lots of paperwork
EAA AutoGas STC
Asking $21,500.00
Located at Taylor Airport (KTYL) in Taylor, Arizona
Best Regards......George
N8547J - 150G - "Scooter"
Updated post with results of recent engine inspection.
Hi George, I see your airport is pretty high. What altitudes do you typically fly when you go? How far away do you have to travel to get lower? Around here in Wisconsin I hardly ever even go to 6000' unless traveling far away.
I was just curious. I like your plane and would seriously consider it if wasn't already in a partnership with a 172. We both agree the 150/152 fits our mission better now.
Good luck selling if she's not already found a new home...
Jim Sainsbury
87Y
N3862L
Hi Jim,
Thank You for the reply and I apologize in this late response, as I have been away form the forum for a while.
To answer your questions, around this local area 7,500 to 9,500 pending direction. Lower surface altitudes are available about 125-150 miles south. BTW, I have reduced the price, see next post.
Best Regards.....George
Priced Reduced to $19,900.00
Hey George,
What's up? Are you trying to start a price war? wink grin
N4629X 1967 150G for sale
RC
Keystone Flight
East Coast Outkast
Originally Posted by Robert_Cressman
Hey George,
Shots fired across the bow!
