P
P Offline
Hello,
I am trying to find a child Seat for my 1966 C150F - preferably with the hardware.
We've priced the new version and while a viable option, it requires a 337, where as the original only requires a logbook entry and updated W&B.
If anyone can help me, I'd genuinely appreciate it. We have a little boy, and if I can't find a solution by next spring, I am likely to move up to a 172. Can't say I would object, but I promised my wife I'd keep trying to find a solution with our present C-150F.
Thanks!
I see the older style seats on Ebay quite often. Have you been searching that site for them?
You should also be aware of what the seat looks like and what part numbers are on it so that when you see a seat come up for auction you can verify it's the proper seat.
For what it's worth, it took me over a year to find the right seat with hardware for my plane. I passed on many seats that were for older planes. Be wary of those ad's that say they fit all Cessna 150's etc. That can not be said of all seats that have been made.
If you have an IPC you have all you need to find the seat, if not post back and I'll look up some data for you.
Matthew P. Cummings
1974 Cessna 150L N10667
Moberly, MO (MBY)
P
P Offline
Matthew,
Thanks - I have been watching EBay, no luck. When they are available it is the hardware that becomes the issue. We gave in and ordered the new version - still cheaper than moving up to a 172 for those few times I need 4 seats, which are indeed few and far between.
Thanks again
Robbie
I'll will be following your lead. I need another seat for children. Please let me know how the process goes. You can email if you want....
Thanks
Please keep in mind that the child seat is only intended to hold one occupant, not two, and that you still need to be cautious with gross weight, baggage weight limitation, and CG in that configuration.
My grandson got too old for mine within 6 months, so I resold it before I even got it installed.
I received this partial email today regarding a new STC child seat. Their website shows all the 150/152 models included in the STC. I am planning on ordering one soon. Hope this helps.
The price of the Ce 152 child seat is $1010.00.
If you have any additional questions, please do not hesitate to contact me. Chuck Koch
Aviation Fabricators/Central Airmotive
805 N 4th Street
Clinton, MO 64735
(660)885-7531
http://www.aviationfabricators.com/cessna_child_seat.htm
Sterling May
1980 A152
Well not quite............ (quoting from their website)
[color:"red"] Applicable Aircraft: Cessna 150D, 150E, 150F,150F, 150G, 150H, 150J, 150K, 150L, 150M, A150K, A150L, A150M, 152, A152, F150G, F150H, F150J, F150K, F150L, F150M, FA150K, FA150L, FRA150M, F152, & FA152 [/color]
Basically, you gotta have a back window or it isn't approved.
Charles
http://150cessna.tripod.com
Quote: Basically, you gotta have a back window or it isn't approved.
It seems to me that there wouldn't be enough headroom without omnivision, is that an optical illusion?
On a similar topic, I frequently get requests for 337's to enlarge the baggage area on the earlier airplanes. Anyone have experience or observations about that issue?
Actually, there was a childs seat for the straight backs, but it was made of the corrugated aluminum like flaps and ailerons, riveted to aluminum angle. Its in the Parts Book. I have one for a Cessna 140, nearly identical but not the same. Need to sell it, just taking up space.
The Childs seat in those early models fit againist the back of the baggage compartment and the seat back was hinged at top so it could lift up for access to the battery. Made the baggage compartment usless for anything else.
Charles
