I just bought my second plane. That's true...you do need a good pre-purchase inspection. If you don't want to pay for one, that's your call. You'll pay later. The pre-purchase inspection is for your benefit, not for that of the seller. That said, I did my own prepurchase inspection when I bought mine and there were plenty of problems that I found, then there's plenty of problems that I've discovered within the first month of ownership. Things I didn't check for, and things that were fine when I checked them.
Welcome back to the club, too. Now with your new plane, we'll see you at Clinton, right?
I agree, this forum will drive you nuts. Well, maybe the people here on this forum will drive you nuts. I'll try.
As for the other subject that's near to my heart...you wanna re-convert your plane back to the taildragger configuration? Good for you. Mine is the Texas Taildragger conversion with the flat steel gear that has been re-arched to sit a little taller. I absolutely love the little critter.
Good luck with the purchase, and welcome.
