| Joined: Mar 2007 Posts: 2,089 Likes: 5 Member/1500+posts | Member/1500+posts Joined: Mar 2007 Posts: 2,089 Likes: 5 | I find myself in the pickle of needing replacement McCauley wheels for a 152 (with SN above 15280900). According to the service manual, I need the "B" option wheels, part numbers listed below. At a minimum I know I'll need 2 inner wheel halves, and possibly 1 or 2 outer halves, so preferably the whole wheels. It's either find some used ones in good condition or bite the bullet and buy the replacement Cleveland wheel/brake kit which is about $1500!  (and it technically requires a field approval, but should be easy with a part-by-part replacement referencing the alternate wheels called out in the service manual) If anyone knows of any available wheels that fit my needs, it would be most greatly appreciated! Wheel Assembly C163006-0101 (i believe includes): Inboard wheel half D30662Outboard wheel half D30657Thanks!
| | | | Joined: Jul 2004 Posts: 21,807 Likes: 2288 Member/20,000 posts | Member/20,000 posts Joined: Jul 2004 Posts: 21,807 Likes: 2288 | Matt,
I may have what you need.
I converted Sierra to Cleveland's last year and have the original McCauley's in my hanger with the old tires still mounted to them.
I have not had them apart in years as I've only serviced the wheel bearings at each annual and that does not require the wheel halves to be separated.
My serial number is 15279996. If the part numbers you have apply to my serial number you're welcome to these.
I really should dismount the tires and look them (the wheels) over for corrosion and cracks to make sure they're okay. One never knows what you'll find.
| | | | Joined: Dec 2003 Posts: 25,438 Likes: 1004 Member/25,000 posts | Member/25,000 posts Joined: Dec 2003 Posts: 25,438 Likes: 1004 | I may have what you need. If the part numbers you have apply to my serial number you're welcome to these. Another great deal from Jim's Trailer Sales & Aircraft Supplies. | | | | Joined: Mar 2007 Posts: 2,089 Likes: 5 Member/1500+posts | Member/1500+posts Joined: Mar 2007 Posts: 2,089 Likes: 5 | Hmmmm.... there are two configs according to the parts manual, A and B. A is for SN 15279406 to 15280899.
B is for SN15280900 and up which is where mine falls. I wounder what the difference could possibly be?!?
So close and so tempting!
| | | | Joined: Mar 2004 Posts: 12,760 Member/10,000+ posts! | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,760 | Hmmm, I've got an xtra 3-pc. pair of:
Cessna Part# C163032-0101 ???
| | | | Joined: Jul 2004 Posts: 21,807 Likes: 2288 Member/20,000 posts | Member/20,000 posts Joined: Jul 2004 Posts: 21,807 Likes: 2288 | Hmmmm.... there are two configs according to the parts manual, A and B. A is for SN 15279406 to 15280899.
So close and so tempting! That's a Chuck Hanna question if there ever was one. Jim
| | | | Joined: Mar 2007 Posts: 2,089 Likes: 5 Member/1500+posts | Member/1500+posts Joined: Mar 2007 Posts: 2,089 Likes: 5 | Any idea what they came off of Bengie?
Yeah, Jim, it's frustrating. We are having a discussion over in Tech Questions, but that discussion is mostly towards upgrading to Cleveland. What approach did you take Jim, buy the "Cessna" retrofit kit? Did the install instructions happen to have a breakdown of all the individual parts? I'm assuming the wheel came with the proper spacers, races installed, and bearings supplied? (not that it's hard to install them, but...)
I'm waiting to get my floor jack and stands back from a friend so I can take the wheels off, clean them up and get any/all numbers off the wheels themselves.
| | | | Joined: Mar 2004 Posts: 12,760 Member/10,000+ posts! | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,760 | Any idea what they came off of Bengie? ebay!  'cept the bolts go all the way thru all 3 pieces.
| | | | Joined: Mar 2007 Posts: 2,089 Likes: 5 Member/1500+posts | Member/1500+posts Joined: Mar 2007 Posts: 2,089 Likes: 5 | haha, nice. 3-piece meaning they are 3-piece wheels or the brake disc being the third piece? Do you have a stockpile of ebay Cessna parts lying around there cause they went for the right price??
| | | | Joined: Mar 2004 Posts: 12,760 Member/10,000+ posts! | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,760 | They're definitely 3-pcs. Left, right and center hub. (6) pcs. if you count both mains. No brake discs. And...... yes.
