I need a 3-1/8” True Airspeed Indicator for a C150. Does anybody have one? I can trade a working-when-removed non-True ASI (range marked for a 1976 C150) plus cash, or buy your TASI outright.
Thanks,
Harvey
Retired USAF Meteorologist
1976 Cessna 150M
1942 Stearman
1942 Harley 45" Flathead
1932 Airway Beacon
2015 22" Sears lawnmower
Several houseplants
Half a bag of Twizzlers...
Anyone?
Hello?
Tap, tap, tap... Is this thing on?
(...Sound of crickets...)
Harvey
1976 Cessna 150M
1942 Stearman
1932 Airway Beacon
Several houseplants
Originally Posted by Harvey_Hartman
Anyone?
Hello?
Harvey
I don't have one.
i don't have one
[Linked Image from hosting.photobucket.com]
Where is that tapping sound coming from? Sounds like my computer was saying something......... Ahhh it's nothing..... darned crickets, where do they come from this time of year.
smile
1976 Cessna 150M
1942 Stearman
1932 Airway Beacon
Several houseplants
All out of TAS indicators, sorry Harvey...
TAS indicator? Hmmm....most of us have IAS indicators; mine has knots on the outside with MPH in a window on the inside ring.
I thought to get TAS, you needed a temperature tie-in?
Indicated, Calibrated, Equivalent, True airpseeds....thought you had to go through the first three to get the last one unless you had a air data computer?
My memory is going, correct me if I'm out of school, Harvey!
MM
Dan Offline
Try Wentworth and some of the other previously-owned-parts dealers Harvey. A true ASI isn't something most owners have laying around. Now if you need a VAL760 that's dead...I gotta deal for you !!! grin
Harvey,
Didja have something like this in mind? grin Something like the one I have in my possession? wink
Problem is, I don't think it would work with a standard 100HP engine, cuz you can't go quite fast enough to utilize the TAS function.
However, it maaaaay work if you had 150HP! grin
Oooooo look....a matching set:
I'm getting there Bengie ... smile
A150M TD; N9832J "Sassy"
