| | Joined: Mar 2004 Posts: 12,760 Member/10,000+ posts! | | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,760 | Here's a set of Courtesy Lights [ cgi.ebay.com] on ebay, although a bit pricy. Normally, they run in the $30-$60 range.
| | | | | Joined: Jun 2004 Posts: 36,117 Likes: 778 DA POOBS Member with 30,000+ posts!! | | DA POOBS Member with 30,000+ posts!! Joined: Jun 2004 Posts: 36,117 Likes: 778 | ...show off... ![[Linked Image from animatedimages.org]](https://www.animatedimages.org/data/media/218/animated-penguin-image-0137.gif) [ animatedimages.org] Imagine a united world. Join the Popular Front for the Reunification of Gondwanaland. | | | | | Joined: May 2005 Posts: 361 Member/250+posts | | Member/250+posts Joined: May 2005 Posts: 361 | Very nice looking panel. I'm jealous.
Charlie R | | | | | Joined: Nov 2004 Posts: 5,465 Likes: 23 Member/5000+posts! | | Member/5000+posts! Joined: Nov 2004 Posts: 5,465 Likes: 23 | But it is cheaper than those after market ones that someone is selling for around $129.00 each, though I think they are individually 9v battery operated and LED
Matt Gray
aerobat@cessna150pilot.com
A150K@hotmail.com
| | | | | Joined: Mar 2004 Posts: 12,760 Member/10,000+ posts! | | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,760 | Good point, Matthew. I had, absolutely, forgotten all about those Aftermarket LED Courtesy Lights [ knots2u.com] that run off of a 9 volt battery. Outta sight... outta mind! (Mostly, out of mind!)
| | | | | Joined: Sep 2004 Posts: 2,701 Likes: 2 Member/2500+posts | | Member/2500+posts Joined: Sep 2004 Posts: 2,701 Likes: 2 | Aftermarket LED Courtesy Lights that run off of a 9 volt battery...Outta sight... outta mind! After I get the gear lowered and the prop shortened I'll be mounting a set with blue lights under my plane's fuselage - ground effect lights - and a pair on the horizontal stabilizer to illuminate my personal insignia painted on the tail.  -Dennis proud owner of 'Pachuco' - a 150G lowrider | | | | | Joined: Mar 2007 Posts: 5,983 Likes: 1255 Member/5000+posts! | | Member/5000+posts! Joined: Mar 2007 Posts: 5,983 Likes: 1255 | Bengie, you always have the coolest stuff for your cockpit! You're my hero! MM | | | | | Joined: Jan 2004 Posts: 18,962 Likes: 4 Member/15,000 posts | | Member/15,000 posts Joined: Jan 2004 Posts: 18,962 Likes: 4 | These replace the inspection covers under the wings... right outside the cockpit doors. I owe Bengie a set... if I ever get around to making buying them!  | | | | | Joined: Mar 2004 Posts: 12,760 Member/10,000+ posts! | | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,760 | You're s-l-o-o-o-w.  Mine are already painted and installed.  Now, go fabricate yourself a set like John Vargo did.
