#238135 12/16/09 11:08 PM
Here's a set of Courtesy Lights [cgi.ebay.com] on ebay, although a bit pricy. Normally, they run in the $30-$60 range.
#238437 12/18/09 06:35 PM
...show off... grin
#238448 12/18/09 09:36 PM
C
C Offline
Very nice looking panel. I'm jealous.
Charlie R
But it is cheaper than those after market ones that someone is selling for around $129.00 each, though I think they are individually 9v battery operated and LED cool
Matt Gray
VH-UEG - A150K
VH-UEH - Airedale A109
VH-UYL - Taylorcraft J2
aerobat@cessna150pilot.com
A150K@hotmail.com
Good point, Matthew.
I had, absolutely, forgotten all about those Aftermarket LED Courtesy Lights [knots2u.com] that run off of a 9 volt battery.
Outta sight... outta mind! crazy
(Mostly, out of mind!) shocked
Aftermarket LED Courtesy Lights that run off of a 9 volt battery...Outta sight... outta mind!
After I get the gear lowered and the prop shortened I'll be mounting a set with blue lights under my plane's fuselage - ground effect lights - and a pair on the horizontal stabilizer to illuminate my personal insignia painted on the tail. smirk
-Dennis
proud owner of 'Pachuco' - a 150G lowrider
Bengie, you always have the coolest stuff for your cockpit! You're my hero! MM
Mike Marra
1977 C-150M N714AJ
Carlisle, PA. Member; Mar '07
These replace the inspection covers under the wings... right outside the cockpit doors. I owe Bengie a set... if I ever get around to making buying them! blush
You're s-l-o-o-o-w. shocked Mine are already painted and installed. laugh
Now, go fabricate yourself a set like John Vargo did. wink
