Page 2 of 5 1 2 3 4 5
Pete_Leibel #164375 10/01/08 01:59 AM
tomahawks... I trained in them. Wish I did my training in a 150 aerobat taildragger!
Jeff Hersom
N3740J '67 150G "Gremlin"
N8634S ‘66 150F/150hp “Rusty”
Places I have landed Gremlin:
Gremlin #164396 10/01/08 04:16 AM
do you guys have any engine gauges(EGT,etc) in the cockpit that you've put in since owning?
Pete_Leibel #164401 10/01/08 04:36 AM
I've put in a fuel flow gauge. I absolutely love it. Next will be 4 cylinder CHT. More useful than EGT - you can lean by ear as well as you can with an EGT, and gives you engine health information.
Jeff Hersom
Gremlin #164404 10/01/08 05:02 AM
ahhh... ok, thanks for that!
are those CHT gauges costly?
Pete_Leibel #164405 10/01/08 05:06 AM
The nice 4 probe CHTs (the only ones worth buying) can be a little pricy... but for knowledge on how your engine is doing, it's a small sacrifice.
Jeff Hersom
Pete_Leibel #164458 10/01/08 05:05 PM
G
G Offline
$1,200 for the JPI EDM-700. I have one.
Geo.
George Abbott, PE
thanks,
so any opinions on that one i mentioned earlier?
If you wonder if something can be put in a 150, just ask Jim H. From autopilot to TCAS, fuel flow, CHT/EGT, IFR GPS, etc... it's all possible. grin
Willymopit #164584 10/02/08 08:07 PM
so is 8000hours just too much on a 150. i know it's relative to the condition,etc. but should i be looking for something with less time on her.
thanks
Pete_Leibel #164587 10/02/08 08:46 PM
There are 150s and 152s running around with more than 10,000 hours. It depends on the condition of the bird.
If the owner is asking top dollar for a run out engine and a corrosion riddled airframe, then run away from it! If it has a mid or low time engine, sound skin and spars, then it may be worth a more detailed look.
Strike up a good relationship with a reputable mechanic. Have him do the pre-buy.
Pat
