#10904 01/23/05 02:46 AM
Does anyone which key blank is used to make a spare door/ignition key for a 1980 152? I had one made a few years ago at an Ace Hardware store. That store is now closed, and none of the local hardware store could find a suitable blank to use. Do I need to go to a locksmith? The key that I have now has "ACS216" marked on it. No Cessna name/logo.
Hey Hung, if you want a little authenticity instead of a regular blank key, check out ebay Item number: 4521288776
Eric Crump [email]ericcrumpatcoxdotnet[/email]
1976 C150M N8747U
DVT Phoenix AZ
Thanks for the tip, Eric. Unfortunately, they don't match the shape/grooves of my key.
I was a afraid of that. Well, what worked for me was the local Home Depot. I wonder if my '76 uses a different key-blank than a 152? I had a spare set made when I bought the plane. I DO remember the guy saying he couldn't match it but he found one that worked.
1976 C150M N8747U
DVT Phoenix AZ
Hung call a lock smith, he will have the key blank. I had to have a lock smith come out to the 182 I flew and make a key for the door since it would not lock it. he made me 4 copies and it cost me 40.00, it took him awhile to get the cuts right.
Richard McCullough
N8508B
Hung,
I think it is an 1122 if that dosn't sound right let me
know and I'll get my new glasses out and look at mine again.
Hung, hope this helps:
Key Blank S2194-2 List Price $3.78 each S2194 series key is for early aircraft. All 120/140, 150, A150, 152, A152, 170, 172RG, 177, 177RG, 180, 190/195, 205, 207, T303.
All other single engine Cessnas through approximately the end of the 1985 model year.
Key Blank P6471-1-8 List Price $2.14 for a package of 10 P6471-1-8 series key for later aircraft starting at the following serial numbers:
172-76479 and on, 185-4441 and on, 182-68528 and on, R182-2028 and on, U20606918 and on, 21064945 and on, P210-0866 and on.
Key blanks can be ordered through any Cessna dealer. If you have the lock number you can order a cut key from Cessna through any authorized Cessna service facility. The Cessna service facility will submit the order to the factory with the lock number, the aircraft model, serial number and registration number along with the owners name and address.
Cut keys cost about $3.50 from the factory.
-John Frank
Does the photo match?
10508-key blank.jpg (0 Bytes, 36 downloads)
1976 C150M N8747U
DVT Phoenix AZ
Eric,
Thank you very much for the info. My key (see attached) appears to match the P6471-1-8, although the info you quoted said it is for 172, 182, 210, etc. The cut on the S2194-x key is the reverse of mine. My key works in both the ignition and the doors, so I don't think the lock was changed from the original.
Ron,
If you have an aftermarket key (ilco, hillman, axxess, etc), could you verify the number on the key for me? Thanks.
Hung,
It's an Ilco, see attachment for the number.
