#106474 08/10/07 12:12 PM
Does anyone happen to have a Glove box door for a 73 L model? That built in handle finally gave up and the plastic ripped out! Thanks---Tim
L
L Offline
Tim,
Is the aluminum hinge still intact, i.e. just the plastic is cracked? If so, Plane Plastics sells a glove box door replacement, part no. K0413525-1. It comes in two halves so you'll need to rivet one half on the hinge and then glue the two pieces together. Really not that difficult.
Larry - Planeless at the moment
