I installed the Skybolt fasteners at my annual in Sept. Relatively speaking it was an easier installation than I originally thought. Most of the work was already done when the 150HP conversion was completed. The rear mounts on the cowl bolted right on. No drilling or template use required. My AI drilled and riveted the rest. The hardest part was the adjustments so it all lined up. So far I love them. Quick and easy to remove. Seems like every long X-country I was replacing missing fasteners before I installed them. Cost is about right. I purchased mine through Texas Aeroplastics. I received a follow-up call from Skybolt to give them TT and Serial number for the paperwork. He even said he would send additional fasteners if more were required due to the new cowl to cover the bigger engine. What they sent filled all the holes. Have your AI file a 337 and you are good to go.
