G
G Offline
I have a fresh overhaul O-200A for sale with no core required.
Assembled and test run by SkyBoss Aviation. Engine has the following:
Case, Crankshaft (-10), Cam, Accessory Case (new oil pump gears) recertified by Airworx
All other metal…gears, rods etc. recertified by Aircraft Specialty Services
(4) new Superior Cylinders with new Piston Pins
Fresh Overhaul on Marvel MA-3SPA Carb
Fresh 500 Insp on both 431 Magnetos with new harness and spark plugs
Has a SkyTec Starter and Plane Power Alternator
This was a 1,271 hour factory reman that started leaking by a through bolt.
Engine is stored in my hangar located Georgetown, TX. Can be picked up or crated and shipped at additional cost.
Gordon Cragg
(713)-502-7274
GordonCragg737@gmail.com
I private messaged you, thanks!
Still available? How much.
A Offline
On March 11th it was listed by Gordon on Facebook Marketplace for $35,000.00 with "no core required".
Antonio Bal
