Hi
Looking for a working Suction/Vacuum Relief Valve Cessna P/N C482001-0101 if anyone has one or knows a good source please PM me.
*NOT the RAPCO/Airborne ones with the garter filter
Thanks in advance!
Mitch
Try Texas Air Salvage
Air Parts
eBay.
Search with the exact part number.
Aircraft Spruce offer this one:
https://www.aircraftspruce.com/catalog/pnpages/10-03895.php
Rapco.
Why don't you want the filter? Used to change mine annually and it was always filthy when I did.
Options
Hi Graeme
You are absolutely correct to search with the exact p/n!
I have no objections to the garter filter but the RAPCO RA2H3-2 is different from the original C482001-0101 used on the older 150s. Different size, fittings and would require some modifications to the hoses....making the install a bit more involved.
There are several on e-bay and in the salvage yards (and apparently Cessna even has a few new ones in stock)
Thanks for your reply!
Thank you Robert!
I was looking at those options. The concern I have with the used ones on e-bay and from the salvage yards is that they are probably 50+ years old and look worse than my original one.
r
So far I am leaning towards possibly a new one.......rather pricey IMO but if it lasts 50+ years it might be worth it
Take care
Mitch
I MIGHT HAVE A GOOD ONE OUT AT THE HANGAR. I WILL CHECK ON MONDAY FOR YOU.
Thank you very much Ronald but I was able to get one
