Mounting hardware for 150 D entry assist straps
#673921 11/11/24 09:31 PM
OP Offline
Restoring my 150D, looking mounting and installation hardware including the covers for the cabin entry assist straps
Jeff Boyd
Re: Mounting hardware for 150 D entry assist straps
Jeff Boyd #673923 11/11/24 11:41 PM
Offline
Jeff, Click below for 74 posts about assist staps from the Cessna 170 website. We also have 150/152 club members with other good ideas.
This data is from their "free use" section. If you wish to respond, search, or make inquires, you must become a 170 club member.
https://forum.cessna170.org/forums/viewtopic.php?t=5216
"Gravity Always Wins"
1 member likes this: Jeff Boyd
Jeff Boyd #673924 11/11/24 11:57 PM
Offline
Cessna 150's are nice in that you can open the Rt side window, reach across, pull the door closed, and then shut the window prior to run-up. An "Assist" strap would also be handy on the aft inside of the Rt passenger door. We ask new passengers NOT to close the door because they pull hard on the fragile door handle, stripping the splines on the shaft and bending linkages. Some of these parts are very expensive or "un-obtainable." For straps, check with a store that sells climbing equipment, or a good hardware store. You need high strength strapping or the internal chain type rope. I made mine from a 1" wide military litter strap.
Good luck in your "search" for a solution.
Jeff Boyd #673946 11/12/24 04:16 PM
Offline
Here is a picture of some I made for my sons plane. Leather over Kevlar paracord .
2 members like this: Jeff Boyd, Joseph B
Jeff Boyd #673947 11/12/24 04:51 PM
Online Content
Jeff Boyd #674009 11/14/24 01:38 AM
OP Offline
Thank you all for your thoughts. I like the straps from Shawn Taylor’s post.
I’m getting the straps themselves and the visors redone by a friend who does leather work.
I was looking for the original mounting hardware
Jeff Boyd
Jeff Boyd #674024 11/14/24 04:09 PM
Offline
Jeff theses are what I used for mounting, then sourced SS screws from Ace hardware
Jeff Boyd #674025 11/14/24 04:36 PM
Online Content
Jeff, From what I see in the parts manual the original attaching hardware is #10 screws.
You do have a parts manual don't you?
Jeff Boyd #674183 11/19/24 04:12 AM
OP Offline
Hopefully I’ve been able to add the photo of the hardware.
Jeff Boyd
