I picked up this early 150 lower cowl with the intention to modify it for a 150HP conversion by replacing the nose bowl with the STC fiberglass one, but then found another cowl that's in much worse shape to use on my project (since I'd be replacing the nose bowl anyway). So, I'm offering up this complete lower cowl to help someone put their 150 back in the air. $550 Located Tucson, AZ
