#670702 08/16/24 10:47 PM
I would like to thank all you guys that sent me info on where we might find a spinner for my airplane. Well it isn't mine anymore but I was helping the new owner try to get a spinner.
He is back in the air now. I do not know yet if he found a new spinner or just what, but he sent me a note thanking me and said he was back in the air.
I will be talking with him soon and find out just what he did for the spinner . Anyway thanks all of you who tried to help us.
Dale Larsen
If over 60 and you wake up in the morning and nothing hurts.....................your dead.
3 members like this: Raymond Olsen, Geoff Vincent, Graeme Smith
Dale Larsen #670746 08/18/24 01:29 PM
E
E Offline
YES!
Please let us know what he did for his spinner!
Thanks Dale!
Ed Figuli #670811 08/19/24 08:34 PM
I’m still trying out a couple of different things on the old spinner. I have build a replacement piece for the missing section lost in flight. I added a “belt “ to a bolster the skirt of the spinner as it fastens to the hub. I was trying to avoid welding the repair because I believe it made the original repair of last year brittle. Hence the reason I lost the small 3x4 in section. I have used adhesives with the belt and have about 7 hours on it but can see that the adhesive is not a long term solution. So as of today it is back on my bench and I am going to weld it with my AL mig. I’m optimistic that the belt plus adhesive plus welding brings me a long term solution. I will add photos and write up.later.
1 member likes this: Ed Figuli
Dale Larsen #670812 08/19/24 08:42 PM
E
E Offline
Thanks for the information Raymond.
Ed Figuli #670863 08/20/24 09:12 PM
Ditto.
Dale Larsen #670914 08/22/24 05:11 AM
Following my welding repair of yesterday and a thirty minute flight I'm feeling like I might have a fix on my spinner. I'm going to try and add some photos with a bit of narrative.
In December at the annual we discovered a 2-3 crack in the spinner. Being pretty new as a solo owner and a new man in a new land (new hanger, new plane and new mechanic) I had it repaired by a fellow recommended by my mechanic. (Pic 1) It came back looking great and I painted it up and installed it. Started flying once the annual was completed in about March as I needed a new carburetor and it took about 6 weeks to get it shipped out. Things went well for about 7 hours of flight time over a couple of months. During a preflight I found that section of the spinner at the repair site had departed during flight. (Pic 2) Discouraged by the "welded" repair earlier I talked with my mechanic and he and I agreed that I could try a couple of epoxy adhesives with a replacement section and a shaped backing plate behind it adding a counter weight to the balance it out. I also added a 1" wide aluminum belt to circumnavigate the entire base of the spinner. (Pic 3 and 4) This worked pretty well but after a couple of flight hours it was apparent that the adhesive repair had a limited life expectancy and while certain that the belt would keep the repair piece from departing it was going to cause problems in micro movement and eliminate any expectation of a pretty paint job. (Pic 5) At this point and having some skill in welding, I was going all in on this spinner, and weld it myself. I have a welder set up with aluminum MIG and so I practiced on some 0.050" aluminum until I thought I was close and welded it up. Too make a long story short I build up the repair with multiple short beads that didn't look like much but as I ground them down and widened the repair area I was careful not to remove too much material from my repair. You will note in (Pic 6) the repair was not feathered completely into the adjoining unwelded area as I wanted to bulk up the thickness and width at the repair site. The material in the spinner is just to thin to grind away with confidence. Pic (7) is a good photo of the "finished" repair with the aluminum belt in place. I'm going to fly it for at least 10 hours now before I get back to repainting it. Or more likely wait until the next annual in March. I did use epoxy between the belt and the spinner mostly just to make disassembly less of a hassle.
This is Dale Larsen's airplane and has the Lycoming 0-360 with a Power-flow exhaust. It is a hoot to fly. Dale took really good care of it for 23 years. My mechanic told me several times that I have myself "a nice airplane". The spinner is obviously not stock. Photos (7 and 8) are of the numbers inscribed inside of the spinner indicating the company, the FAA-PMA STC SA750 CE and the part numbers from the spinner AVCON C-150 15012-5. I would gladly purchase a spare spinner if anyone in the club should come across one.
Thanks for all
Raymond
