WINTER IS COMING
You can't get these anymore.......
Originally Posted by Manufacturer Blurb
The LT 2-12 MH-300 features a heat sensor located near the air outlet that will shut off fuel to the burner if the preheater surface temperature exceeds safe levels. Other safety features include electronic Piezo igniter for clean, reliable ignition; safety shutoff valve which shuts off fuel flow if flame goes out; adjustable regulator for variable BTU output; and excess flow P.O.L. which limits the flow of fuel if there is a sudden surge due to a malfunction in the fuel line. The 10' power cord has alligator clips for quick attachment to a 12 volt D.C. source. A 5-foot fuel hose allows convenient connection to any LP-gas cylinder.
As shown in photograph with all original documentation. Hard Shell Carry Case.
Does not include the original 90 degree bend (you can get one at your local Home Depot / Lowes) and does not include the air delivery hose which you need to make up to suit your application/aircraft. See picture for how I did it. There are instructions in the documentation. I used AC Duct and an insulation sleeve from the home improvement store.
With a thick blanket over the cowl and no wind you can get the engine completely warmed through, oil thinned down and into "summer start" mode with about 30 mins heating.
Well looked after in storage box. Probably 40 preheats over 10 years. Almost looks new. Burner orifice recently cleaned (a 1/32" drill to remove carbon build up). Runs and heats great!
Dimensions (L x W x H)
19.98 x 10.28 x 10.95 IN
Package Weight
21.5 LB
Heat at outlet
49000 Btu
Electrical Draw
4 Amps @ 12 VDC
$150 plus shipping of your choice. Cash / Check / PayPal (+5%)
Pm sent
Graeme,
I have one and use it on occasion. For a while, it was ALL I had and kept me flying through the winters for years as I base OUTSIDE...especially during BOMB CYCLONE years!
Very good...nice piece of kit!
I connected all the elements and attached them to a trolly so we could move it around easier with the propane tank, etc.
It's a good heater and effective even down to 0-10 degrees F.
Mike Marra
1977 C-150M N714AJ
Carlisle, PA. Member; Mar '07
I'd be all over this, if I hadn't already built my own preheater.
This is a $1200 value if you bought it new.
Eschew obfuscation!
Currently with Robert.
Mike - yep - the instructions include a couple of plans for dollies.
Jeff - well they don't make them anymore - at least not this model. I based the price on examples going on eBay.
In a later iteration (not pictured) I put insulated socks on the metal prop blades to prevent conduction/radiation losses during heating. Made a remarkable difference. Took about a third of the time off heating.
It is a really convenient and economical way to pre-heat.
I never had to go more than 45 minutes for a toasty engine, oil bag, or other components - it got ALL the various metals to the SAME TEMP (or nearly so) facilitating a smooth start!
Still have it, though now, since the airport installed POWER near my spot, I simply "plug in" to the Reif System. Still kept the DRAGON, however!
Mike Marra
1977 C-150M N714AJ
