C
C Offline
Evening. I found a bit of an issue with my copilot seat the other day and well…I need a new one or atleast the bottom frame portion of the seat. Soooo I’m on the hunt for a seat with one of the 3 Part Numbers:
0414070-2
0414084-2
0414090-2
It’s a normal reclining one, not one of the kickass vertical adjusting one. I really only need the frame for the seat bottom but will take a whole seat also if the price is right…upholstery doesn’t matter to me as I’ll be hopefully replacing it here soonish.
Thanks in advance, the closer to Nebraska the better.
Cam Walther - N93468 “Dimple Darlin”
Hallam, Nebraska, USA
Cameron, what’s the problem with your’s ?
Often these seat frames can be welded.
C
C Offline
The rear shaft that controls the recline has been bent and broke thru the corner brace. I was going to take it into work and see if my Metal Tech guys could possibly fix it if I can find a new shaft
C
C Offline
[img]http://[/img]
Hopefully this works (posting the photo)
I ran across this from a ‘65 150F
Co pilot seat [texasairsalvage.com]
It’s not cheap, but I don’t know what your price range is. Maybe they will part it out for you?
C
C Offline
Update- found one actually locally! Picking it up this weekend
