#655289 08/08/23 03:05 PM
As much as I truly love my C150, the siren song of a faster more capable airplane is calling. That said, looking to put my bird up for sale. For sure, this is not a fire sale, I enjoy flying her, and will continue to do so until sold. She's going into the avionics shop next week for the AvMag install. (which should put to rest concerns about the AV30 drifting, Please excuse that some of the pictures are not totally current. The panel picture with the dual AV30s is the most recent. The Garmin and Apollo GPSs, which were dead, have been removed.
That said, here's the scoop
1971 (1972 model year) Cessna 150L N150LJ s/n 15072865
Avionics
TKM MX170 Navcom (no glideslope)
King KT76a Transponder with encoder
Falken Avionics Flight Box Pro (v1, similar to https://www.falkenavionics.com/flightbox-pro/) Installed with external ADS-B in antenna. Provides VFR GPS, AHRS, ADS-B in
Sigtronics SPA-400 Panel Mounted Intercom
Dual uAvionix AV30c. Installed with uAvionix AvMag (no drifting DG)
uAvionix AV20
AirGizmo iPhone dock
Apple XS Max (currently being used with WingX, can use with EFB of your choice)
Garmin dual USB power
Current pitot-static and transponder checks
uAvionix SkyBeacon ADS-B out
Pointer 3000-10 ELT
Includes spare King KX170 NavCom
Equipment
Hooker style dual shoulder harnesses
Tanis engine heater
Whelen LED landing light
Powder coated engine baffles
Lord shimmy dampener
Skylights (both replaced new 2021)
Gregoire leather yoke covers with PTT
Towbar
Wheel Pants (not installed, nose pant needs fiberglass repair)
C150 Club belly drain STC
Vacuum pump deleted (no vacuum instruments installed )
Millenium Cylinders
Forensics Detectors CO alarm
Fiberglass Wing Tips
Spin on Oil Filter
Rudder AD complied with with kit (yes you can spin this one)
Condition
Exterior –
paint 6/10. Normal scuffs and fading for 20 year old paint.
Light hail damage marks
Interior –
Relatively recent seat covers and padding
Interior plastics 8/10
Overall 8/10 appearance
Aircraft History
Logs indicate aircraft was disassembled in 1995 for runway excursion. 337 on record for sheet metal repair.
Tail tie down was damaged last year (wind damage while in tie down). It already had a doubler from previous damage. Shop removed doubler, installed new bulkhead piece that holds tie down ring and installed new doubler. 337 filed
Annual due October 2023. Last annual was extensive and brought everything current.
Scanned logbooks available on request
Total Time Aircraft – 7607
TSMOH --1420
Listing with pictures attached -- Asking $40K I can be reached at sgrillo at flytwa.net
Attached PDF document
BTW. If you look at the Flightaware history you can see she hasn’t been a hangar queen, but I’ve been flying her.
Good luck with the sale, Scott.
Let us know what your plans are for your next plane.......your options are wide open.
Good luck with the sale.
Not sure of my plans. Part of me would like a Mooney, the other part wants to keep it simple and would be open to a 150/150 with IFR radios
Sold
