#643509 10/13/22 09:56 PM
W
W Offline
Anybody have some #8 acorn nuts for a C-152 that I can buy? I need two. Would buy four if you have them. Thanks
Threaded #8-32 acorn nuts, also referred to as crown hex nut, blind nut, domed cap nut, are usually available at your local hardware, Lowe’s, Cabela’s, Home Depot, McMaster, Fastenal, Lighting Fixture Supply or Marine store. They may be Brass, Stainless, Black Oxide, Aluminum or Nylon.
Click here:
https://www.google.com/search?rlz=1...A4UQ1QJ6BAg0EAE&biw=1266&bih=569&dpr=1.5
"Gravity Always Wins"
W
W Offline
I found the acorn nuts at my local Ace Hardware, but the Cessna panel nuts have a rim that fits down in the panel threads. The acorn nut above has a flat bottom, and it won't grab the threads.
Thanks for the reply.
Aircraft Spruce has them if you can not find them cheaper somewhere else.
https://www.aircraftspruce.com/catalog/appages/cessnaparts27.php?clickkey=58012
James Rhoades, A&P/IA
5729E '59 150TD "BarFly"
N76040 '46 120 SOLD
