#637782 05/10/22 07:16 PM
Does anyone know where we might find a C2401 spinner for our Sensenich 69CK-0-48L prop?
Apparently they're no longer in production, and used ones don't seem to be plentiful.
I've been looking for a bit. I put the skull cap on in the mean time
Experience is a hard teacher because she gives the test first, the lesson afterward.
The only time you have too much fuel on board is when you're on fire.
We've been using a skullcap as well. But that spinner doesn't look bad. The BN-1 and C2401 are different spinners, but my understanding is that either one will fit a 69CK series spinner--is that correct?
I bought one of the ebay spinners because it was cheap enough to experiment with. He had two. I couldn't find any information about the part number but it looked like it would at least provide me with some parts to work with if it was wrong.
It fits my sensinech almost perfect. I need to take a file and "adjust" the forward bulkhead screw holes a little but i think it will work fine. Haven't had a chance to sort it out yet so still running a skullcap.
Thanks for the tip and the info about your spinner. We also decided it was worth the risk. The spinner is supposed to arrive on Thursday.
If it works out, it'll be a great find.
