#633286 01/06/22 02:16 AM
G
G Offline
I have a set of long range tanks in a Cessna 150G I am parting out. However, the airplane sat for a number of years and the filler necks and associated parts have rusted beyond salvage.
Does anyone in the community have any fuel tank parts I could purchase. The needed parts are the same as the standard range tanks. Thought I would try here before hitting the salvage yards.
Gordon Cragg
(713)-502-7274
GordonCragg737@gmail.com
Are you selling the long range tanks? If so, PM me the price.
1967 Cessna 150G
Lifetime Member
2016 & 2019 Top Gun Pilot
Gordon, Aircraft Spruce [aircraftspruce.com] has filler necks.
Only $17.75 ea. I have changed them on a 150 that sat for many years and the originals were rusty.
Hi,
Don't mess with them since the interior ring cannot be removed unless the tank is cut open the ring cleaned up or replaced then the tank is re welded then install the new parts.
If rusted the neck filler is screwed into the interior ring and is usually pinged in the treads so even if you try to unscrew the filler you will rip up the tank.
You can cut the filler neck in to 3 places trying not to damaging the threads and take them out in pieces but risky business..
New fillers can be had as mentioned. Gaskets from Mcfarlane can be had.
Best you can do is send it to hartwig fuel cell repair. Spoke to them a few times and they are the only ones I know that can bring them back to life...
Link:
https://www.hartwigfuelcell.com/repairmetal.php
The wings have parts in them for the conversion of standard wings to LR wings that are needed to convert standard wings.
If you use the original parts in the wings you just need a 337 describing the conversion referencing parts manual and get them signed off (NO STC).
Installation would be another 337 to install to be safe..
Don't try to remove the rusted parts yourself. you will not be happy with the results and most likely destroy very rare tanks..
SAVE the Wing parts... also impossible to find.
1 member likes this: Skypidgeon
