Removed from Mighty Mouse:
Garmin Aera 660 portable GPS (750.00 new)
Airgizmo panel docking station (125.00 new)
Wiring harness to hard wire unit into ships power (87.00 new)
The above components were installed new in MM in 2017 and were removed for his recent panel upgrade when the GTN 750 and JPI EDM930 were installed.
I'll let this entire package go for 500.00.
It's cosmetically perfect with no scratches, smudges or flaws of any kind and it works and functions perfectly and seamlessly.
A Garmin GDL 51 (with an Sirius XM subscription) with give you XM WX or XM entertainment or both depending on what you want.
A Garmin GDL 52 will get you the above plus A-DSB 'in' displayed on the screen.
FYI: I have both A-DSB free WX and XM WX and the XM system has many, many more WX data points and blows the A-DSB WX into the weeds.....but you pay for it.
If you don't have room in your panel or don't want it panel mounted you'll need to source a yoke mount (I may have those components as well which I'll be glad to include free if I have them but I need to check). Regardless though, the wiring harness above will handle the yoke mount position as well so you're still hard wired into ships power. I may/may not even have the cigarette lighter plug in power cord but will need to check on that as well?
That’s a real bargain for somebody, Jim! I’m sort of holding out for something like a GPS 175. Good luck with the sale. It will be a short one, I predict!
I wish I had known, bought a unit at Osh and had it hardwired. Good luck sale should go quickly at that price.
PM sent Jim
TK
1969 C-150J
N5520G
States we have landed the green machine!
The Aera 660 is sold and moving to Wisconsin.
Now that gorgeous hunk of metal, glass and electronics called a GNS530 needs to find a new home while it navigates someone all over the country in style. smirk
That was quick!
tempting... but I think I should hold out for a W unit. frown
