G
G Offline
I was asked to go through a recently deceased friends hangar and found that he still had the “Kiddie” seat from his 150.
This seat has been on a shelf in his hangar and, in my opinion should be reupholstered.
Good news its is all there with the following P/N’s
0400134-5 Frame Assembly
0711098-7 Hinge-Floor Fitting LH
0711098-8 Hinge-Floor Fitting RH
0400136-6 Seat Bottom Assembly
0400131-1 Seat Back Support Assembly
0400138-1 Support Assembly-Backrest LH
0400138-2 Support Assembly-Backrest RH
0711080-1 Backrest Assembly
PLEASE NOTE:
THERE IS NO HARDWARE EXCEPT FOR THE FLOOR HINGES. THERE ARE NO SEAT BELTS. ALL OF THE AN227-8 STUDS ARE IN PLACE. THESE IS A VERY SMALL AMOUNT OF SURFACE CORROSION IN AN ANGLE OF THE SEAT BACK SUPPORT, NEEDS TO BE CLEANED AND RE-ALODINED.
PRICE IS: $800.00 PLUS SHIPPING
Gordon Cragg (713)-502-7274
B737Jock@aol.com
G
G Offline
Sold thanks to the Club.
2 members like this: David Hempy, Ron Stewart
Perfect......glad you got it sold and someone will get some good use out of it.
