#607559 08/23/20 08:16 PM
In search of crankcase vent tube , 0-200 1970 150K
Thanks
Joe
Joe Bryant, Current driver & Caretaker of N5687G 150K [Linked Image from visitedstatesmap.com]
Just to clarify, do you need the aluminum tube that exits the cowl, the elbow that is installed in the engine case, or both?
Experience is a hard teacher because she gives the test first, the lesson afterward.
The only time you have too much fuel on board is when you're on fire.
I just replaced my crankcase vent tube with the Aerobat style vent tube. If you want my old standard vent tube, let me know you can have it for postage. Now if you want the Aerobat style, then expect to spend $200.00 to buy one or if you know someone who brazes metal, they can make one for you. PM me for info on either option.
Thanks guys. I’m only needing the tube that extends out to the bottom of the cowl.
Joe
You can probably fabricate it yourself. Get the ID and OD dimensions and length. Then call WICKS Aircraft and order the tubing you need.
Thanks Ron.
