#597887 02/21/20 02:04 PM
For sale is a used O-200 push rod tube setup. Everything looks to be in great shape....EXCEPT for 1 pc large flat washer that is bent (see picture attached)
What you see is what you get. Asking $265USD shipped to ConUS. PayPal OK.
Dave Rigotti
N9340U
That right there is a PHENOMENAL deal and a very high order upgrade for your leaky pushrod tubes. Properly installed, these things almost completely if not 100% solve that common problem on the 0-200
Any idea of the age on this set? Should the seals be replaced when installing? (the 8 black and 8 red rings on the right side of the picture)
... I might try and call Real Gaskets today and see what they think.
I don't think that those are Real Gasket push rod tubes. They are made different from the Real Gasket tubes that are on my engine.
I wonder if they are from the newer Continental cylinders.
1961 172B. N7909X
(Sold)1974L N11573
Sterling NE
0G3
Huh. They do look different....
Originally Posted by Dave_Rigotti
For sale is a used Real Gasket push rod tube setup for an O-200. Everything looks to be in great shape....EXCEPT for 1 pc large flat washer that is bent (see picture attached)
This looks NOTING like the set I bought 3 months ago and an now installing on my O-200. I will talk pictures of mine and post in a day or two.
OK mystery solved.....I'm selling these for a friend at the airport. MY BAD..I misunderstood him. These are from his O-200 that he replaced with Real Gasket types. I thought he said THESE were Real Gasket ones.
So...These are NOT Real Gasket, but Continental brand.
Dave Rigotti
N9340U
Thanks for cleaning that up and the clarification, Dave.
This is interesting......obviously its not a Real gasket pushrod tube set...BUT....they are different than the stock Pushrod tubes. Is this something Continental put out? Or is it something found on newer builds/overhauls of the O-200's ? here is a pic showing the real gasket setup on the left....and the stock tube install on the right. This still looks like an improvement over the stock parts to me.
They look like the push rod tubes from a Continental O-200D Sky Catcher engine and not the certified O-200 used on the 150.
