#588931 07/30/19 01:52 PM
I had stockpiled these items for my pet 150 project.. Instead I need to sell them to fund my instrument, multi, and cfi ratings... Oh well, right? So let's get to it, I can crate and ship with the company of your choice.
1962 Cessna 150b $8500 Airframe is straight, the motor is timed out 2200 SFOH. A/C is currently in trike config, but has the custom aircraft conversions conventional gear stc (Texas tail dragger) it needs a Scott tailwheel and a couple of days to make it right again. It is also STC'd for mogas I had the O320 and crank for the williams 150/150 stc(not included). The current O200 runs but has 0 compression in one cylinder, I wouldn't hesitate to ferry it with a cylinder O/H or replacement, as the others have good compression, and it isn't using oil or making metal. it's last annual was 2016. The main photo is what this plane will look like as a 150 /150 TD
Lycoming O320 timed out core with logs $4500
Lycoming O320 crankshaft, Zero time, rebuilt with yellow tag by Precision Airpower
Lycoming and 150 $11,500
Feel free to text or call for details and pictures
Guy Zindel
801 389 1230
I'm pleased to sell together or separately
Would you happen to have the prop spinner used on the Williams( Bush )150/150 STC?
I do not but Bob says he has them. I've talked with a few gents that have done transactions with him in the last year and they have all received there stc's and parts without issue.
Has the plane sold?
Are the logs complete?
Where is it located?
