| | Joined: Feb 2014 Posts: 2,391 Likes: 1 Member/1500+posts | | Member/1500+posts Joined: Feb 2014 Posts: 2,391 Likes: 1 | Strikemaster, very cool! The last time I saw one was in Saudia Arabia. It be a ton of fun to fly.
The Early Bird gets the worm, but it's the Second Mouse that gets the cheese. Chandler, AZ KCHD 1973 A150L Sold RV-6A Hela | | | | | Joined: Feb 2009 Posts: 2,706 Likes: 155 Member/2500+posts | | Member/2500+posts Joined: Feb 2009 Posts: 2,706 Likes: 155 | Strikemaster, very cool! The last time I saw one was in Saudia Arabia. It be a ton of fun to fly. Unfortunately, the only way this particular Strikemaster will ever fly again is if it is pushed off a very high cliff. https://www-265.aig.com/AviationSal....pdf&Extension=pdf&Type=p&PictureId=6873
| | | | | Joined: Jan 2010 Posts: 2,316 Likes: 54 Member/1500+posts | | Member/1500+posts Joined: Jan 2010 Posts: 2,316 Likes: 54 | So you were looking for a strikemaster tail when you bid?
Henry N2011X - 1965 C182H
| | | | | Joined: Feb 2009 Posts: 2,706 Likes: 155 Member/2500+posts | | Member/2500+posts Joined: Feb 2009 Posts: 2,706 Likes: 155 | Got the logs for the 140 yesterday. It has a 115HP O-235 that was overhauled last year, along with VGs, tail handle, big tires, and other STCs.
Hmmmmm.... Not sure I want to sell it now.
| | | | | Joined: Jan 2015 Posts: 5,102 Likes: 23 Member/5000+posts! | | Member/5000+posts! Joined: Jan 2015 Posts: 5,102 Likes: 23 |
| | | | | Joined: Sep 2012 Posts: 1,208 Likes: 68 Member/1000+posts | | Member/1000+posts Joined: Sep 2012 Posts: 1,208 Likes: 68 | I have 120/140 parts....
You are lucky, the left wing usually takes the hit during a ground loop. Used Right wingtip parts are more plentiful than the left.....
| | | | | Joined: Feb 2009 Posts: 2,706 Likes: 155 Member/2500+posts | | Member/2500+posts Joined: Feb 2009 Posts: 2,706 Likes: 155 | Would you have a right gear leg to sell me? It’s be nice to be able to trailer it home on its feet rather than its belly.
| | | | | Joined: May 2016 Posts: 441 Likes: 1 Member/250+posts | | Member/250+posts Joined: May 2016 Posts: 441 Likes: 1 | Would you have a right gear leg to sell me? It’s be nice to be able to trailer it home on its feet rather than its belly.
just a thought here... bout why not weld the gear leg back together for the trip home? Butt weld then place a scab plate over the weld on the bottom side and weld. Would be a quick fix and would work for the ride home. That said... I may know someone interested. Will speak with him today.
| | | | | Joined: May 2016 Posts: 441 Likes: 1 Member/250+posts | | Member/250+posts Joined: May 2016 Posts: 441 Likes: 1 | If you're still wanting to sell it let me know. | | | | | Joined: Feb 2009 Posts: 2,706 Likes: 155 Member/2500+posts | | Member/2500+posts Joined: Feb 2009 Posts: 2,706 Likes: 155 | I'm really curious to see it now. I've been wanting a tailwheel for a while and I'm intrigued by this one.
Brilliant idea on the temporary leg. Rather than weld it, I will see if I can fabricate a bolt on sleeve
