Some of the Cessna 150 parts I’m selling from my aborted rebuild project. Several of these have photos in my rebuild thread, but PM me for current ones if they aren't already posted here. Did my best to describe things accurately and to the best of my knowledge, but I’m not infallible smile ; I encourage stopping by and inspecting the parts personally if possible. Larger parts require local pickup of course, but I can assist with loading.
Please have your mechanic or AP do a full inspection to determine air worthiness and suitability.
Left and Right Wings (from a 150G) - I removed and paint stripped the flaps and ailerons. I also removed and cleaned the electric flap motor, landing light lens, and gas tanks (standard range). All are included. The right flap was already damaged when I got it, and I did purchase a replacement (which is not paint stripped). You’ll have your choice of taking the original flap that came with the wings, or the replacement. I also purchased used replacement flap roller bearings which are included. I have the N-number of the donor plane the wings came from if needed. $800 OBO
Wing Struts – (p/n 0426606 & 0426606-1) Very nice condition. Fully paint striped (not by me). $100 OBO
Wing Strut Spacer – (p/n 0523307) This was a spare I picked up. $10 OBO
Fuselage (150F) - Former N8921S. No data plate. For messing around with only, as it is not airworthy and cannot be made airworthy. The exterior has been fully paint stripped (except for the landing gear legs), and I have cleaned/degreased the inside area around the rudder pedals. Most parts have been removed, but still has or comes with the following (I make no claim as to airworthiness of the parts):
- pulleys & control cables
- fuel and interior brake lines
- trim chain and wheel
- main landing gear legs
- steps
- glove box with home-made replacement cover (no, not made by me!)
- original cables that attach to the instrument panel, such as for cabin heat.
- wing strut plates
- nose gear steering rod boot plates
- brake cylinders
- main gear wheels
$300 OBO
No longer available
Tail Cone Assembly – (p/n 0412020-202) From a 150G. Needs a repair around the tie-down bolt (small crack and a little indentation); appears as if someone scraped the tail during a take-off! Otherwise in decent condition, but has some surface corrosion (I gave it a coat of ACF-50). The donor aircraft serial number is on it if needed. $50 OBO
