Originally Posted by Elliot_Cannon
Can ANYTHING on our airplanes be repaired with a heli coil? Someone in this group must know this. Anyone?
Case studs, exhaust studs... Probably more...
This brings up another question. Can aircraft engine spark plug holes that are stripped out be repaired with a heli coil?
I'm pretty certain the spark-plug holes come from the factory with Heli-Coils, as the aluminum threads wouldn't hold up in service.
My last cylinder replacement required a heli coil.
Terry Monday
1976 C150M N9463U
Greenville, NC
I believe this to be accurate as well......If I'm wrong, I'm in very good company. smirk
So there's a good chance then that this can be an approved repair for my fuel tank. My offer still stands. $0 plus shipping if anyone wants it.
My mechanic had to install some Helicoils when replacing cylinders a while back because the case studs were stripped. The procedure is described in the O-200 maintenance manual. See this post and the two posts following.
Roy
[Linked Image from eznec.com]
I wonder if it will be another year and a half before Molly posts again.
Apparently she doesn't want my fuel tank. Although something might be preventing her from replying, who knows? Any way if my tank can be fixed with a heli coil, the price just went up. smile laugh
