| Joined: Jan 2015 Posts: 5,096 Likes: 21 Member/5000+posts! | Member/5000+posts! Joined: Jan 2015 Posts: 5,096 Likes: 21 | Can ANYTHING on our airplanes be repaired with a heli coil? Someone in this group must know this. Anyone? Case studs, exhaust studs... Probably more...
| | | | Joined: Dec 2003 Posts: 14,791 Likes: 548 Member/10,000+ posts! | Member/10,000+ posts! Joined: Dec 2003 Posts: 14,791 Likes: 548 | This brings up another question. Can aircraft engine spark plug holes that are stripped out be repaired with a heli coil? I'm pretty certain the spark-plug holes come from the factory with Heli-Coils, as the aluminum threads wouldn't hold up in service.
| | | | Joined: Aug 2010 Posts: 5,194 Likes: 258 Member/5000+posts! | Member/5000+posts! Joined: Aug 2010 Posts: 5,194 Likes: 258 | My last cylinder replacement required a heli coil.
| | | | Joined: Jul 2004 Posts: 21,784 Likes: 2277 Member/20,000 posts | Member/20,000 posts Joined: Jul 2004 Posts: 21,784 Likes: 2277 |
I believe this to be accurate as well......If I'm wrong, I'm in very good company. Jim
| | | | Joined: Sep 2015 Posts: 1,324 Likes: 57 Member/1000+posts | Member/1000+posts Joined: Sep 2015 Posts: 1,324 Likes: 57 | So there's a good chance then that this can be an approved repair for my fuel tank. My offer still stands. $0 plus shipping if anyone wants it.
With a mile of highway, you can go one mile. With a mile of runway, you can go just about anywhere. | | | | Joined: May 2009 Posts: 4,529 Likes: 367 Member/2500+posts | Member/2500+posts Joined: May 2009 Posts: 4,529 Likes: 367 | My mechanic had to install some Helicoils when replacing cylinders a while back because the case studs were stripped. The procedure is described in the O-200 maintenance manual. See this post and the two posts following. Roy
States where I've landed my 150 | | | | Joined: Feb 2009 Posts: 2,706 Likes: 155 Member/2500+posts | Member/2500+posts Joined: Feb 2009 Posts: 2,706 Likes: 155 | I wonder if it will be another year and a half before Molly posts again.
| | | | Joined: Sep 2015 Posts: 1,324 Likes: 57 Member/1000+posts | Member/1000+posts Joined: Sep 2015 Posts: 1,324 Likes: 57 | Apparently she doesn't want my fuel tank. Although something might be preventing her from replying, who knows? Any way if my tank can be fixed with a heli coil, the price just went up.
