| Joined: Feb 2004 Posts: 1,814 Likes: 418 Member/1500+posts | Member/1500+posts Joined: Feb 2004 Posts: 1,814 Likes: 418 | What burning questions need to be answered at the maintenance forums this year? Enquiring minds want to know to plan them. Alan Core | | | | Joined: Mar 2004 Posts: 10,432 Likes: 864 Member/10,000+ posts! | Member/10,000+ posts! Joined: Mar 2004 Posts: 10,432 Likes: 864 | The hot topic lately appears to be what can the owner do and what needs additional sign offs by A&Ps or AIs. Maybe a discussion about how to use the service manual as well. | | | | Joined: Mar 2004 Posts: 15,884 Likes: 990 Member/15,000 posts | Member/15,000 posts Joined: Mar 2004 Posts: 15,884 Likes: 990 | The hot topic lately appears to be what can the owner do and what needs additional sign offs by A&Ps or AIs. Maybe a discussion about how to use the service manual as well. +1
Ron Stewart N5282B KSFZ | | | | Joined: May 2011 Posts: 387 Member/250+posts | Member/250+posts Joined: May 2011 Posts: 387 | As aging owner of an aging aircraft (neither fact of which can be ignored), I'd like to hear a discussion of what a reasonable approach to Cessna SIDs (supplemental inspection documents) might look like…mandatory "down-under", of course, but which have simply been incorporated into our service manuals. From posts on this site, it appears some items specified in SIDs may be picked up on annual, others not so much. When should I pull the headliner/insulation to examine the carry-through spar? On what basis should these inspections be initiated … on a sliding scale according to airframe hours, by a past history in tie-downs or years in the Florida Keys, in response to owner pireps on the forum, etc, etc? Would a borescope be a worthy investment for leisurely investigations by owner?
John Sixbey C150M KTXK (Texarkana)
| | | | Joined: Sep 2006 Posts: 8,775 Likes: 300 Member/7500+posts | Member/7500+posts Joined: Sep 2006 Posts: 8,775 Likes: 300 | As another aging owner of another aging aircraft, I really don't know enough to know what questions to ask.  I do know I am beginning to think our C-150 has the wrong spinner because it covers most of the oil cooling holes. During the winter and in cooler weather, our temperature and oil pressure are okay (oil pressure maybe a couple of needle widths above the bottom of the green arc, temp a little below half way in the green). When the weather gets warmer (80F or so and on up), the temp goes up over half way and the oil pressure barely into the green. Chuck Hannah had quite a dissertation here a while back. My question is would the covering of the oil holes be enough to cause this problem?? | | | | Joined: Jun 2004 Posts: 35,560 Likes: 559 DA POOBS Member with 30,000+ posts!! | DA POOBS Member with 30,000+ posts!! Joined: Jun 2004 Posts: 35,560 Likes: 559 | How about the following: -engine break-in -steering rods -painting -fuel tank maintenance and refurbishment -proper lubrication for flap tracks. For starters. ![[Linked Image from animatedimages.org]](https://www.animatedimages.org/data/media/218/animated-penguin-image-0137.gif) [ animatedimages.org] Imagine a united world. Join the Popular Front for the Reunification of Gondwanaland. | | | | Joined: Feb 2004 Posts: 1,814 Likes: 418 Member/1500+posts | Member/1500+posts Joined: Feb 2004 Posts: 1,814 Likes: 418 | Got it. | | | | Joined: Feb 2014 Posts: 2,391 Member/1500+posts | Member/1500+posts Joined: Feb 2014 Posts: 2,391 | A demo n installing Real Gasket push rod tubes:-)
The Early Bird gets the worm, but it's the Second Mouse that gets the cheese. Chandler, AZ KCHD 1973 A150L Sold RV-6A Hela | | | | Joined: Oct 2007 Posts: 2,600 Member/2500+posts | Member/2500+posts Joined: Oct 2007 Posts: 2,600 | What John Deere tractor grease is best for a 150 or 152 by model year?
| | | | Joined: Jun 2011 Posts: 19,141 Likes: 2329 Member/15,000 posts | Member/15,000 posts Joined: Jun 2011 Posts: 19,141 Likes: 2329 | A demo n installing Real Gasket push rod tubes:-) On your plane no doubt........  | | |
