Chris,
I very strongly suggest you sh*tcan the weak TCM starter clutch assy, and convert to the Skt-Tech lightweight starter. I got mine from Cheif Aircraft for about $500 thereabouts, and installed it in the course of my major overhaul.Once you have the new starter, you will never have that slipping problem again. You can also sell your old starter on ebay to offset the cost of the new one.The installation is very easy, it seems the hard part is getting the cowling off! No FAA337 is req'd as the Sky-tech is FAA/PMA for the original one.You will have to do a simple W&B adjustment, as the Sky-tech is lighter than the factory Prestolite ( not really -lite at all) starter.
-Brian
