| Joined: Jun 2007 Posts: 286 Likes: 8 Member/250+posts | Member/250+posts Joined: Jun 2007 Posts: 286 Likes: 8 | Lyle, I'm sure you will receive a commission check from Bengie for your suggestions in this transaction. Be watching your mailbox! | | | | Joined: Aug 2007 Posts: 1,976 Member/1500+posts | Member/1500+posts Joined: Aug 2007 Posts: 1,976 | Lyle, if Bengie's case does not work out, I have a case. It is not cracked, but does have a flaw and would need to go to Divco or someone to be repaired.
Philip Mitchell Attorney, CFI, A&P N150BP C150L | | | | Joined: Aug 2010 Posts: 567 Likes: 29 Member/500+posts | Member/500+posts Joined: Aug 2010 Posts: 567 Likes: 29 | Lyle, I'm sure you will receive a commission check from Bengie for your suggestions in this transaction. Be watching your mailbox! Wade, it's I that owe Bengie.
1961 172B. N7909X (Sold)1974L N11573 Sterling NE 0G3 | | | | Joined: Jul 2004 Posts: 21,778 Likes: 2277 Member/20,000 posts | Member/20,000 posts Joined: Jul 2004 Posts: 21,778 Likes: 2277 |
You and the rest of the world......the world is a better place with Master Po. Jim
| | | | Joined: Dec 2005 Posts: 2,657 Member/2500+posts | Member/2500+posts Joined: Dec 2005 Posts: 2,657 | FYI My Lycoming 0-235 had the case repaired 15 years ago and is still in fine shape.
[ Linked Image] The Turtle ( I`am slow, but I get there ) Steve `83-C152 N94270 Tracker http://aprs.fi/#!call=a%2FN94270&timerange=3600&tail=3600 | | | | Joined: Dec 2003 Posts: 14,791 Likes: 548 Member/10,000+ posts! | Member/10,000+ posts! Joined: Dec 2003 Posts: 14,791 Likes: 548 | FYI My Lycoming 0-235 had the case repaired 15 years ago and is still in fine shape. What kind of repair?
| | | | Joined: Dec 2005 Posts: 2,657 Member/2500+posts | Member/2500+posts Joined: Dec 2005 Posts: 2,657 | The case was welded, were I do not know, I have looked for a weld repair to check it and it must be covered up somewhere.
