#487294 09/07/15 07:37 PM
Anyone have them???
There are Old Pilots and Bold Pilots, but no Old Bold Pilots
Here is a pic
With the backing plates on the mains, angle bracket on the front and the extended (heavy) nuts on the mains - I think they come out at 18lbs total but I'm not sure about the arm.
I think those particular ones (in the picture - above from Scott) will only fit if you have the 600x6 wheels and tyres on the mains, if you've got the smaller 500x5 wheels/tyres which a lot of the D and E models came out with, you'll need the smaller wheel pants of the earlier models..see pic's below
..That said, some of our more informed A&P's might be able to chime in here to confirm...
Matt Gray
VH-UEG - A150K
VH-UEH - Airedale A109
VH-UYL - Taylorcraft J2
aerobat@cessna150pilot.com
A150K@hotmail.com
I don't know of any D models with them but they were optional with the E and F models. The best way to tell if you have the 6" wheels on the E model is if you have the HD nose gear. The torsion links on the nose gear point forward on the HD version. Also the corners of the firewall are reinforced with a 1/8" doubler as well.
Niall
1965 C150E N3952U
ASEL IFR A&P
Army Aviation Veteran
