#476622 05/17/15 02:29 PM
G
G Offline
This kit and paperwork was put together by Mike Sibley. I was going to install in a 150E, but priorities have changed.
Includes STC paperwork and drawings. Shipping from Texas on the Kit. Shipping from Alaska for the re-arched gearlegs. $4,500 plus shipping from both locations.
Will also be listing a 150HP Del-Air conversion kit shortly with a 250 SMOH O-320-E2D
Gordon Cragg
713-502-7274
Does the kit have the gear box?
I have 140 legs already........interested in the kit
K Offline
That must make it difficult to buy trousers off the shelf. And how many more do you think you'll end up with? wink
G
G Offline
The 140 legs will not work with this TW kit. It uses re-arched 150G legs. All is included with the kit.
Gordon Cragg
713-502-7274
T
T Offline
Hey Joseph, the 140 gear legs are only for the Lowe STC. and that stc is only for the 59-63 birds.
Correct!
A Offline
Although I did call Lowe in the last year - and he is working on getting his STC approved for the 64 and 65 models. I think he already has one built (or is in the process of building - he said it will look like a mini bird dog). He said there is no difference in the actual conversion as far as the fuselage goes - the only difference is the window.
I've always kinda wanted a tailwheel '64-'65, but only with the 140's tailfeathers. Now, that would really look like a baby L-19/O-1 Bird Dog! It wouldn't be hard to do, by using the 140's tailcone to mount them properly (and it comes with a tailwheel already)!
Approval through 'normal' channels might be a little iffy, but I'm sure it can be done.
T
T Offline
Except Cessna already tried it and the test pilot almost endoed the plane when he pulled the massive Fowler flaps...it needs the bigger tail.
