| Joined: Jun 2005 Posts: 34 Member | Member Joined: Jun 2005 Posts: 34 | Hi, Looking at buying a set of cowl plugs to keep the birds and other critters out. I'm looking at the $34.50 onese from Aircraft Spruce: http://www.aircraftspruce.com/menus/ps/cowlplugs.htmlAnyone have any experience with these or have others to recommend? Regards,
Greg 57D (Ray Community) in S/E Michigan N5290Q - 1972 150L
| | | | Joined: Jan 2005 Posts: 1,492 Likes: 4 Member/1000+posts | Member/1000+posts Joined: Jan 2005 Posts: 1,492 Likes: 4 | My ever-evolving plan is to use the foam-in-a-can crack sealer to make cutom plugs, molded in place. Still have to test if a open weave cloth will contain the foam while allowing it to cure; it will not cure if sealed up in plastic. Of course, my "philosophy" is why spend a perfectly reasonable amount of money when you can waste a lot more time and effort re-inventing the wheel
'75 C150M/150 . N45350 Pitch for Speed ; Power to Climb | | | | Joined: Dec 2003 Posts: 2,134 Member/1500+posts | Member/1500+posts Joined: Dec 2003 Posts: 2,134 | I've seen some with tiny pennants (flags) that stick up above the cowling so that you won't forget they're installed and takeoff. A friend of mine with an RV-6 took off with the cowl plugs installed last week and almost cooked his engine. I made cowl plugs out of a swimmer's kick board. Cost me nothing as I had the board, a rope and a "remove before flight flag." It doesn't have the tiny flags but the two plugs are connected by the rope and if I left them in, the prop turning would catch the rope and fling them off.
Tim '76 C-150M, San Antonio
| | | | Joined: Aug 2005 Posts: 117 Member/100+posts | Member/100+posts Joined: Aug 2005 Posts: 117 | I bought a set from Ground Tech Corp. Planecover.com, Jim Cancil. Phone 800 825-1245. They were custom made and have my N number embroidered on the plug. I don't remember what I paid, I think it was around $40 it was lumped in with a plane cover I bought at the same time. They fit snug in the nose of my 152 and the are tied together with a strap that can be wrapped around the prop, so if you do forget to remove them the turning of the prop will pull them out. Of course that may be the last you ever see of them  I have been very pleased with the cover and the plugs.
Bob '79 152 N68608 | | | | Joined: Feb 2004 Posts: 9,864 Likes: 952 Member/7500+posts | Member/7500+posts Joined: Feb 2004 Posts: 9,864 Likes: 952 | I'm with Bob. I also bought a set from Jim at Ground Tech. They are the best.
Mark Buchner East Coast Outkast Fearless Leader and Cessna 150-152 Fly-In Foundation Director of Operations | | | | Joined: Mar 2004 Posts: 15,929 Likes: 1007 Member/15,000 posts | Member/15,000 posts Joined: Mar 2004 Posts: 15,929 Likes: 1007 | Mine are also from Ground Tech (Plane Cover) [ planecover.com] I think they are about $50 now but worth it!
Ron Stewart N5282B KSFZ | | | | Joined: Feb 2004 Posts: 169 Member/100+posts | Member/100+posts Joined: Feb 2004 Posts: 169 | I bought my cowl plugs at Cee Bailey's. they fit great, but when they embroidered my N#, they put it on upside down. They sent me another set a week later, again the # was upside down. I cut the numbers off and gave up. [color:"blue"]Rick Crosby N11529 aka "Storm Trooper"[/color] | | | | Joined: Apr 2004 Posts: 4,204 Likes: 1 Member/2500+posts | Member/2500+posts Joined: Apr 2004 Posts: 4,204 Likes: 1 | Funny you should ask. I just bought a set from Aircraft Spruce. Save your money. They're too small. Buy some styrofoam or something and make your own. Save the $34 for fuel!  | | | | Joined: Jan 2004 Posts: 4,968 Member/2500+posts | Member/2500+posts Joined: Jan 2004 Posts: 4,968 | You just gave me a great idea. I have some high density foam that was in boxes my instruments were packed in that I was going to throw away....might make a couple of great cowl plugs. I even can probably find some vinyl to cover them with . Now all I need is a piece of wire and a battery to build a hot wire cutter and I am in business. | | | | Joined: Dec 2003 Posts: 7,197 Likes: 2 Member/5000+posts! | Member/5000+posts! Joined: Dec 2003 Posts: 7,197 Likes: 2 | Of course, my "philosophy" is why spend a perfectly reasonable amount of money when you can waste a lot more time and effort re-inventing the wheel <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
A fellow do-it-yourselfer...I love it! I've reinvented countless wheels <img src="/ubbthreads/images/graemlins/grin.gif" alt="" />
