Hey all,
Looking for a 150m lower panel plastic, to use as a pattern for some hole spacing. Junk or broken would be great.
This is the model that has the fuel/oil gauges on the right side upper panel.
I have a metal, powder coated (dark grey), laser engraved (with white lacquer lettering), lower panel I will sell you for $350...;-)
and all the holes are already cut. wink
Thank you Bill, I have seen your panels and they are amazing. I happen to have a CNC table in my garage and I'm fairly handy with my CAD work, so I thought I'd give it a go. (For my plane, no one else's, no worries)
How much of a pain is it to put in a new lower panel from Bill?
My plastic overlay looks like crap on both sides and a nice new panel might do wonders for the old girl.
Yep, my lower panel is slowly disintegrating. I'd like to get a new lower from Bill. And switch from fuses to CBs as well. Maybe this fall.
Tim
Chandler, AZ KCHD
1973 A150L Sold
RV-6A Hela
The biggest pain is removing the throttle and mixture controls completely in order to thread them through the new panel.
Which is also a great time to replace them with vernier control cables....
Originally Posted by Robert_Hansen
Hey all,
You may be better off making your own cardboard template. The plastic wasn't a precision item to begin with, and may have warped/shrunk/stretched due to age.
No problem... That should be a fun project!
Not going to lie...It's a major pain in the Butt!!! You have to disconnect the Throttle, Mixture, carb & Cabin heat, fresh air, parking brake, electrical switches......well you get the picture.
The good news is, when your done the airplane will look better than it did new;-)
