Where is a good place to purchase this?
I see some list it as 0452200-1-279 (updated?)
I'm replacing the cowling also.
Do you have a picture of that part? I'm curious to see what an Air Scoop/Fairing looks like.
I Googled that part number. There appear to be lots of these available new, cost around $550-$600. (for example: www.cessnaparts.com [cessnaparts.com]). Most call it "Fairing." One site calls it "Scoop."
Are you sure that's the right part number for a C-150G? Do you have access to the correct parts manual? Check here:
http://mrwebman.com/aviation/cessna/manuals/
Visit the CalDART website:
www.caldart.org [caldart.org]
That is the plastic fairing around the air filter opening in the cowling. The last three digits now added following the original part number (-279) is the color code (black, in this case). Color doesn't matter, as it will likely be painted to match the cowling anyway.
Still available new from Cessna, but as noted, any new Cessna part is outrageous in price. Used parts are available at sometimes huge discounts, but no two identical parts will have the same rivet hole alignment (even if they are removed without further damage). Most small aircraft (including Cessnas) use a minimum of pre-drilled alignment holes, with the rest drilled by hand. Used parts often require oversized rivets to gain proper hole alignment.
Google "aircraft salvage" to obtain listings containing sources for used parts. There are many, probably some local to you. Also check Ebay.... which never ceases to amaze me as a parts source.
