Howdy I was getting ready to ebay some avionics and gyros but thought I would see if anyone here was interested. It is a complete Narco stack. I was planning on keeping the Comm 2 and Xponder but was planning on taking out everything else.....antennas and wiring included. Until last fall One Charlie Mike was used as an instrument trainer/cheap instrument time builder. The horizon and vac pump are a year old and some of the radios have been serviced recently. I have been offered $2500 for the 12D and 122 but would like to make it a complete package. The only problem I know of is that the loran is not heavy enough to be a good doorstop. The vac system is also everything......filter, regulator, pump(O-320)& mini suction gauge.
Also available is the tail cap with Whelen beacon, PS engineering intercom, wheel pants with backing plates, axle nuts, & that metal plate on the nose fairing.
[Linked Image] [s297.photobucket.com]
I went through the paperwork and this radio stack consists of:
CP 136 M Audio Panel with marker beacon receiver
Mark 12D Nav/Com and ID 825 indicator with glideslope
DME 890
ADF 841 and 841 rotating azimuth indicator
Nav 122 with glideslope and marker beacon
loop/sense adf antenna
CI-102 marker antenna
Narco DME antenna
comm antenna
150 cat whisker antenna
all coax antenna cable labeled and uncut(except nav coax to the fin)
harness intact and all ends labeled
I would like to get $4000.
For $5000 I will include PS Engineering PM1000II
HAPI Avionics master switch
all mic and phone jacks
all circuit breakers
You would just have to hook up the avionics master and a ground.
We could also talk about an install at Clinton
Please let me know if these prices sound inline or if I am a crazy 150 driver.
Thanks, Joey
The vacuum package :
Rapco 211CC pump installed April 2012/ 56 hours
Sigma Tec Artificial Horizon 23-501-06-16 installed December 2012/ 27 hours... all filters and hoses installed new at this time.
Directional gyro with rotating azimuth
Turn and Bank
vacuum regulator
vacuum filter
suction gauge
I would like to get $1200 for this
Thanks again, Joey
I am trying to get the Airglas nose fork, 6" nose wheel, and 8.5s with only spending airplane money.....aka free money. The fork is $2625 and the wheel, tires and tubes are $1694.10 new from spruce for a total of $4319.10....so, that's what I want to get for the gyros/radios. A trade for a set of Flint tanks would also be cool. I am planning to be at Clinton. If someone is interested, we could arrange a test flight.
Thanks
I love my new 8.50s and Airglas fork, good luck!
N1138Z - 1969 Cessna 150J
"ZULU"
