That jack is one of the best tools I ever purchased...and I got mine just before the guy stopped making them. It was designed to lift ANY fixed-gear single engine Cessna, and it is built very stout-it should because the pad is at least 3/4" plate steel, and has a heavy rubber pad glued to the surface to prevent scratches and slipping. The base that sits on the jack arm is also literally built like a tank, and came with adapters to fit standard floor jack arm holes. I cannot remember what these sold for, and you could probably have one made yourself if you knew of a machine shop with a plasma cutter and hydraulic press to bend to the contour of a Cessna belly. Lot of work to cut out, bend, weld together, grind then powder coat.....$$$$$$$$$$$$$$$$$$
Here you can see the mounting base detail:
Linked Image]
As you can see, the pad tips back as the nose is raised, and it also swivels 360 degrees in the jack arm.
The placement is at or just fwd of the rivet line of the bulkhead structure.
Oh, the company was Aircraftjack (dot) com
http://www.youtube.com/watch?v=Bouita_7j3g
