WTB C150 '59-'63 David Lowe Tailwheel Conversion
#392073 03/05/13 01:43 AM
Jeff K Offline OP
OP Offline
We're looking for a '59-'63 tailwheel 150 converted with the David Lowe STC. Will also consider a '59-'63 nosewheel 150 that is in nice shape.
We'll broaden our search if we're unsuccessful, but thought we'd start here.
We're located in Northern California.
Thanks,
Jeff
jeffk . flying at gmail . c o m
1959 Cessna 150 Tailwheel
Re: WTB C150 '59-'63 David Lowe Tailwheel Conversion
Jeff K #392076 03/05/13 01:57 AM
Offline
Jeff,
I saw a clean '59 C150 that's in So Cal, polished aluminum and black on barnstormers.com. It however has a nosewheel and seems like a decent price. It looked real clean, I don't know if I could put a tailwheel on it, just too nice of an airplane.
Niall
1965 C150E N3952U
ASEL IFR A&P
Army Aviation Veteran
Niall G #392078 03/05/13 02:08 AM
Jeff K Offline OP
OP Offline
Hi Niall,
Thanks for pointing out that beautiful 150A. I had run across it and also thought it looked really nice as it was. The engine has 1900+ hours on it and I was hoping to find an aircraft with lower engine times (isn't everyone). Our last aircraft had a run out engine on it and I'm not keen to turn around and overhaul in the short term.
Thanks for your reply.
Jeff
Jeff K #392079 03/05/13 02:21 AM
Online Happy
There is a 1959 on Ebay right now. SMASH HERE [cgi.ebay.com] It will need some paint but it does not look that bad. It is a nose dragger but David could fix that for you. He may even be able to paint the tail when he does the conversion. David Lowe [taildraggeraviation.com]
James Rhoades, A&P/IA
5729E '59 150TD "BarFly"
N76040 '46 120 SOLD
