Page 1 of 5 1 2 3 4 5
Dont supose anyone knows anything about this bird do they?
N5938G
http://dallas.craigslist.org/ftw/for/3143545628.html
I've contacted the seller and he has sent me some info on the aircraft and pictures of the avionics stack and a run down of what the plane has and what has been fixed in the 09 and 10 annuals. I'm waiting on the scanned copies of the engine and airframe log books and plan to try to get over to look at the plane later this week or next week.
I'd be using this bird to complete my flight school and then probably hanging onto it as I love these little planes. I have so much fun flying them.
1970 Cessna 150K
7000 TT Airframe
700 SMOH
Annual expires August 31 2012
STCS/ 337-S installed
Electroic Aileron trim
Spin on oil filter
Circuit breaker replacement for fuses
Wing tip strobes
Venier mixture control
Shoulder harnesses
All Ads up to date
Logbooks from 2004 forward. Prior was destroyed in previous owners house fire. Have complete FAA file on CD.
Avionics and insturment panel updated Sep 2009
Narco:
Mk 12B Digital flip flop w/o GS
ID824 VOR.LOC indicator
CP136 audio panel with marker beacon
DME890 Digital DME with groundspeed and TTG
Sigtronics two place intercom with push to talk
Post light insturment lights installed
Compresson check is 70 or better on all cylinders
The following items were replaced during the annual inspection of 2009
Magnetos
Tires
Main gear wheel assembly
Main gear brake assemblies
Altimeter
Voltage regulator
Elevator control horn bearing
The following items were replaced during the annual inspection of 2010:
Spinner bulkhead
Vacuum Filter element
Intake filter element
O-rings on RH brake assembly
Some pictures
Student Pilot
Huffman Aviation
Fort Worth Spinks Airfield
I am based at WEA (Parker Co.) and have been working on another 150 on the next row over from where it is currently parked. Even took a picture to write down the registration.
Presently, the nose gear strut needs air/fluid service, and it could definitely use a washing, but that is as much as I really know about it. The FBO mechanic and his IA stopped by it days ago for a few minutes - perhaps this was the estimate he received for the spot of corrosion mentioned in the CraigsList ad.
I will be out there tomorrow and will look closer and get some more pictures.
N5938G
'75 C150M/150 . N45350
Aileron trim in a 150???? shocked
Awesome stuff Konrad. I really appreciate any info you can find out from poking around. The seller is slow to get back to my e-mails. I've been waiting on the logbooks since last night.
Are you an A&P? I might need someone to do a prebuy on it laugh
If I get an aircraft it will be my first aircraft purchase so any pointers from anyone would be greatly appreciated.
Student Pilot
Huffman Aviation
I do have an A&P, but as the annual is due soon, I suggest working a deal with the owner to combine the pre-buy with the annual. Thus an IA would need be involved. Any airworthy squawks in the annual can be negotiated in the agreement - owner covers them, or they discount the price, or whatever. If you could work it out to do an owner-assisted annual, with you standing in for the owner (and saving him some $), that is about the best way to go about checking it out, IMHO. While competent, and I have used their IA before on mine, the local shop would not be my first choice to do it.
I was probably going to use the mechanic at Huffman Aviation depending on price. Dunno this whole thing is getting a bit daunting lol.
Student Pilot
Huffman Aviation
What Konrad said. Good Luck.
Originally Posted by Bob_Simmons
Aileron trim? Who knew?
Can't be a tab in the actual ailerion - must be just that it adjusts the rigging of the ailerons relative to the yoke? Right?
Anyone know?
If it is in flying shape, looks like a great buy!
I think they call it having "potential" (followed by a row of "if's").
Regardless......good luck.
