#305528 03/21/11 04:06 PM
Looking for the Blue Book on a 2009 Remos GX AV1. Does anyone know how to get that info other than paying for the online service?
Fly It like you OWN it...
You can get a rough value on the AOPA website. [aopa.org] I think you have to be a member to access it, though.
John
'81 C-152
N6298M
Trade-A-Plane has an on line aircraft evaluator. However, you have to subscribe to TAP, but then doesn't everyone wink
I got both let me check them out... Thanks
132k AOPA worked the NAAA didn't list the Remos... frown
Are you buying one?, or selling one?
G-AWAW [g-awaw.org]
trying to buy
I do not believe in any VREF. Only you know the exact value of your aircraft. YOU know how it looks, how it flies, and all the items that are new, rebuilt, old, etc etc. If a VREF SAYS 18K AND YOU HAVE 27K INTO IT,then it's a great deal for someone espesially if yo have great compressions and no oil leaks or usage. TBO's are just a recommendation thats why the FAA does not make them mandatory. I have seen engines go well over 1000 hrs beyond TBO and still be safe and reliable...
Jim Kent
Wondering about your thoughts on the Remos.
I flew one for the first time a month ago and was frankly astounded to find there was no baggage area. I was looking for something that my wife could take on short weekend trips but that took it out of the picture fast.
Good performance, impressive for the power, it easily out climbs and out runs a 150/152 and burns less gas, but very rudder limited. I would not like to deal with much crosswind.
With no baggage area I am curious why a person would buy one as a personal airplane unless she or he did not plan on ever carrying a passenger when going on an overnight trip.
Best regards,
Rick
Jim,
Over the years I've found Vref to be pretty accurate.
You rarely get what you put into an airplane out of it at sale, which is why buyers look for an airplane with all the bells and whistles already installed rather than put them in after purchase. Paying $20,000 or so to put in dual 530s and a coupled autopilot in a 150 isn't going to increase the sale value of the airplane by that much; just doesn't happen. (Although I've sure met sellers who spent some time thinking that because they had %40,000 in a 150 that they should get that out of it at sale before the realities of the market disabused them of the notion. None came close.)
Agree with you 100%, TBO is only a bit of information. But without solid engine monitor information, oil analysis results, good compression check and clean borescope results, a buyer is going to shy away from an engine that is well past TBO "just because". sigh
A friend has a 310 with both engines more than 1,000 hours past TBO, running great. He monitors the heck out of them and runs them lean of peak to keep temps down (which is one reason they lasted so long) but recognizes that the resale value of the airplane right now is with runout engines.
Best regards,
Rick
