| | Joined: Oct 2009 Posts: 152 Member/100+posts | | Member/100+posts Joined: Oct 2009 Posts: 152 | I am considering wheel pants for my L model; I have the brackets but the pants that came with the purchase were off the plane and the seller only had two. Turns out they are busted up and they are the plastic ones that aren't practical to repair. Does anyone in the east texas area have some they would like to sell?
Jeff Haskin N6512S | | | | | Joined: Feb 2004 Posts: 5,975 Member/5000+posts! | | Member/5000+posts! Joined: Feb 2004 Posts: 5,975 | Jeff, Be aware that there are several different styles of wheel fairings used on the Cessna 150, and as many different backing plates as well. If you cannot find a set from a club member or another private party, you can source them on eBay quite regularly. You should post a photo of the backing plates installed on your plane to determine the ones you should be looking for- what you have installed may not be original to your plane. -Brian | | | | | Joined: Oct 2009 Posts: 152 Member/100+posts | | Member/100+posts Joined: Oct 2009 Posts: 152 | Thanks Brian, My brackets are wider (taller) in the front. I have noticed some brackets are shaped different. I will see If I can find a picture--pictures are always good.
Jeff Haskin N6512S | | | | | Joined: Feb 2004 Posts: 5,975 Member/5000+posts! | | Member/5000+posts! Joined: Feb 2004 Posts: 5,975 | The ones with the opening taller in the front are most likely the 1971-73 year, and the wheel pant itself has distinct "flats" over the top of the fairing. Everything from 1974 on up uses the rectangular backing plate and the modern rounded style fairing. What year is your "L"?
| | | | | Joined: Mar 2004 Posts: 12,760 Member/10,000+ posts! | | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,760 | > THIS THREAD < and the associated illustrations may help you.
| | | | | Joined: Oct 2009 Posts: 152 Member/100+posts | | Member/100+posts Joined: Oct 2009 Posts: 152 | Mine is a 1973L model; manufactured late 1972
Jeff Haskin N6512S | | | | | Joined: Oct 2009 Posts: 152 Member/100+posts | | Member/100+posts Joined: Oct 2009 Posts: 152 | Very helpful info. Thanks Bengie
Jeff Haskin N6512S | | | | | Joined: Mar 2004 Posts: 12,760 Member/10,000+ posts! | | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,760 |
| | | | | Joined: Dec 2003 Posts: 7,197 Likes: 2 Member/5000+posts! | | Member/5000+posts! Joined: Dec 2003 Posts: 7,197 Likes: 2 | I was thinking there were basically 2 styles of backing plates, the early and the later ones(?) But I don't know where the break was.
| | | | | Joined: May 2009 Posts: 3,366 Likes: 7 Member/2500+posts | | Member/2500+posts Joined: May 2009 Posts: 3,366 Likes: 7 | Jeff!
Welcome to the "18 members" ONLY section of the club!
Matt Walsh has N18205 I'm custodian of N18506
and now you!
Mine was born on September 15, 1972... | | |
