The price of a new tube looks quite reasonable to me,, factoring in that it's a cessna part. Have you already taken it off? A few things to consider,, and if you are watching anything on a watch list,, I'd have a really close look at the cylinder portion, where the bearing is mounted to the lower section. When I had mine off this winter, for a "seal replacement", things got a bit more interesting when I removed the complete assembly and found the lower bearing was worn out, and that it had "worn some fairly severe grooves on the cylinder part. So. from my perspective,, there are 2 things to really watch for. The inner tube condition,, dents and pitting, and the second part would be the condition of the cylinder with bearing included. Everything else is fully useable and there should be no reason to replace any of the other parts,, other then o rings that is. But,, I'd check the lower bearing,, and I'm not so sure it can be checked correctly when the strut is mounted. If you require pointers for the roll pin removal, let me know as I'd made up a niffty jig for that little portion of the "removal process". As well, I'm a bit of a pack rat,, on the hardware portion I don't typically reuse old parts,, as in a roll pins. It was cheaper for me to purchase a few of these,, so, I have a few spares,,,
I should mention, providing the outer cylinder doesn't have damage,, like being bent or dented, the bearing wear or grooving into the cylinder can be repaired. When I called Cessna for a price of that puppy,, for a few minutes I had this thought I'd just get a new part,, but a 2 minute phone call re-arranged my thinking. If I recollect correctly, it's roughly 15 to 20% of the cost of purchasing a nice 150. That woke me up in a hurry.
