Page 3 of 4 1 2 3 4
The MaxPulse looks like a nice unit. The Pulse Light has two settings: a slower setting for daytime use and a faster one for nighttime. The unit also comes with two lamps much brighter than stock. The original lamps can't be used with the Pulse. Also, it stops pulsing when you turn on the landing light (or you can turn off the pulse.) I installed both lamps so I can have a spare on board if the landing light fails.
Doug Anderson
N8458J, Amazon Temptress
Originally Posted by Gary_Shreve
Tell 'em I sent ya, and you'll have to pay a tolerance fee. So, mum's the word!
Now that's funny! laugh laugh laugh
Good one Gary!
Wayne
"Plane Crazy"
Pardon me. I meant the Max Pulse unit. Simple to install and appears to be a good value.
John
150-61401
C-FUUE
Originally Posted by Wade_Spooner
Well it happened to me, too. The landing light in my 73L quit working yesterday. I went to my NAPA store to purchase a GE 4509, but they did not have one in stock. But the parts store did have a GE 4537, which has a candlepower of 200,000. The 4509 only has 100,000. The parts store catalog stated both lamps pull around 7 amps, both 12 volts, both 100 watts. Would there be anything wrong installing the 200,000 candlepower bulb?
Technically illegal, because it's not been certified in any way for our Cessna's.... but I did make a note of the part number for future reference! smirk
Thanks, Wade! wink
Hmmmm..... http://www.bulbconnection.com/ViewItem/bcrw/itmid/1472/oc/4537/item.html
A lot cheaper than Spruce has them. A little more googling shows prices less than $8 each. As my last light lasted about twenty minutes before it cracked, I'm feeling a bit ripped off.
G
G Offline
There's an excellent Tech Note No. 006 at Cessna Pilots Assoc. website:
"The Good and Bad News About Landing Lights"
Wink
Originally Posted by Bengie_Phillips
(Pirep after the annual) wink
Annual???? confused
What annual are you referring to? grin
The everlasting annual. frown
I'm experiencing the 'snowball effect' this year, mostly self inflicted. cry
Bengie, thanks for the link to MaxPulse.
Now if I can just get a pulsed backup light.
Harry
Originally Posted by dranders
The MaxPulse looks like a nice unit. The Pulse Light has two settings: a slower setting for daytime use and a faster one for nighttime. The unit also comes with two lamps much brighter than stock. The original lamps can't be used with the Pulse. ....
I'm considering getting the MaxPulse and no where have I seen that it comes with lamps or that the existing lamps can't be used. Can you elaborate??
Page 3 of 4 1 2 3 4
