| Joined: Dec 2004 Posts: 757 Likes: 1 Member/750+posts | Member/750+posts Joined: Dec 2004 Posts: 757 Likes: 1 | The MaxPulse looks like a nice unit. The Pulse Light has two settings: a slower setting for daytime use and a faster one for nighttime. The unit also comes with two lamps much brighter than stock. The original lamps can't be used with the Pulse. Also, it stops pulsing when you turn on the landing light (or you can turn off the pulse.) I installed both lamps so I can have a spare on board if the landing light fails.
Doug Anderson N8458J, Amazon Temptress
| | | | Joined: Mar 2004 Posts: 1,698 Member/1500+posts | Member/1500+posts Joined: Mar 2004 Posts: 1,698 | Tell 'em I sent ya, and you'll have to pay a tolerance fee. So, mum's the word! Now that's funny!  Good one Gary!
Wayne "Plane Crazy"
| | | | Joined: Jun 2006 Posts: 1,024 Likes: 1 Member/1000+posts | Member/1000+posts Joined: Jun 2006 Posts: 1,024 Likes: 1 | Pardon me. I meant the Max Pulse unit. Simple to install and appears to be a good value.
John 150-61401 C-FUUE
| | | | Joined: Jan 2004 Posts: 18,962 Likes: 3 Member/15,000 posts | Member/15,000 posts Joined: Jan 2004 Posts: 18,962 Likes: 3 | Well it happened to me, too. The landing light in my 73L quit working yesterday. I went to my NAPA store to purchase a GE 4509, but they did not have one in stock. But the parts store did have a GE 4537, which has a candlepower of 200,000. The 4509 only has 100,000. The parts store catalog stated both lamps pull around 7 amps, both 12 volts, both 100 watts. Would there be anything wrong installing the 200,000 candlepower bulb? Technically illegal, because it's not been certified in any way for our Cessna's.... but I did make a note of the part number for future reference!  Thanks, Wade!  | | | | Joined: Feb 2009 Posts: 2,706 Likes: 155 Member/2500+posts | Member/2500+posts Joined: Feb 2009 Posts: 2,706 Likes: 155 | Hmmmm..... http://www.bulbconnection.com/ViewItem/bcrw/itmid/1472/oc/4537/item.htmlA lot cheaper than Spruce has them. A little more googling shows prices less than $8 each. As my last light lasted about twenty minutes before it cracked, I'm feeling a bit ripped off.
| | | | Joined: Apr 2008 Posts: 15 Member | Member Joined: Apr 2008 Posts: 15 | There's an excellent Tech Note No. 006 at Cessna Pilots Assoc. website:
"The Good and Bad News About Landing Lights"
Wink
| | | | Joined: Jul 2004 Posts: 21,826 Likes: 2294 Member/20,000 posts | Member/20,000 posts Joined: Jul 2004 Posts: 21,826 Likes: 2294 | (Pirep after the annual) Annual???? What annual are you referring to? Jim
| | | | Joined: Mar 2004 Posts: 12,760 Member/10,000+ posts! | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,760 | The everlasting annual.  I'm experiencing the 'snowball effect' this year, mostly self inflicted.
| | | | Joined: Dec 2003 Posts: 258 Member/250+posts | Member/250+posts Joined: Dec 2003 Posts: 258 | Bengie, thanks for the link to MaxPulse. Now if I can just get a pulsed backup light.
Harry | | | | Joined: Dec 2003 Posts: 258 Member/250+posts | Member/250+posts Joined: Dec 2003 Posts: 258 | The MaxPulse looks like a nice unit. The Pulse Light has two settings: a slower setting for daytime use and a faster one for nighttime. The unit also comes with two lamps much brighter than stock. The original lamps can't be used with the Pulse. ....
I'm considering getting the MaxPulse and no where have I seen that it comes with lamps or that the existing lamps can't be used. Can you elaborate?? | | |
